Was there A Door in the Tunnel?
Hi Folks,
In any B 17 Y1B thru G, was there ever door in the floor between the pilots, that covered the top of the tunnel to the nose compartment? I have not heard of this anyone?
Thanks,
Tim
Thanks,
Tim
Fighters at 12 O'clock high
Re: Was there A Door in the Tunnel?
Is there a door here?
Doors from the TO
Thanks was this standard? removed or deleted later on?
The door was there from the early models through the E. I've seen it
In early F drawings, but don't know at what serial number they were discontinued.
I'll look into it and post when I find some time.
From the blueprints:
The doors in the floor leading under the flight deck were there
late into the B-17F production run.
Note: Boeing built only - I do not have data for Douglas and Vega
Metal doors with corrugation (as shown in the TO drawing above)
ran from the B-17B through the B-17E, (Possibly earlier but I
cannot confirm the 299/YB-17 usage at this time), and the
first 320 examples of the B-17F from S/N 41-24340 --> 41-24639
and S/N 42-5050 --> 42-5069.
Wood doors were used from S/N 42-5070 --> 42-5484 and
S/N 42-29467 --> 42-30505
Leaving the B-17Fs S/N42-30506 --> 42-31031
and all B-17Gs doorless.
Boeing Bee 42-29782 fits in there - did it get wooden doors when it was restored?DryMartini wrote: Wood doors were used from S/N 42-5070 --> 42-5484 and
Boeing Bee has tunnel doors installed there is a walk thru on-line that shows them:
https://my.matterport.com/show/?m=ArPe3NZ5f1o
From the BAD June 1943 memo mods to be accomplished before entering service
Removing the cockpit floor doors is item 7
